Opening Day 2008
Discussion in 'Drag Racing' started by Rick, Mar 4, 2008.
  1. Rick
    Rick G8I operations
    Ocala, Florida
    Me and my Buddy headed to our local track Sunday for opening day and as some of you know I rebuilt my top end this winter so I really wanted to see how it would do since the car is really running strong. On my 3rd pass I launched good at 3k slid all over the place but managed to stay in it and get down the track bad part is as soon as I went through the traps I got an very loud surprise at 102mph that propelled me upward then parts were flying every where. So now I need a new tranny, drive shaft and a starter. Lots and lots of pieces, what a mess.
    :character0182:
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    WOW! do you race at captial? or MIR?
    that sucks a big un
  3. mavman
    mavman Member
    Arkansas
    You are very lucky you still have all of your appendages! Seriously, a friend of mine called today...same problem. He has a Isuzu pickup with a 408" windsor, runs low 6's in the 1/8 on spray. First pass with the "new" truck, the driveline broke and when it did, the part that was still attatched to the transmission swung around. Took out the planetary, floor, shifter was blown off of the tunnel and hit the roof, with his hand still on the shifter the whole time. That driveshaft in the Isuzu was a stocker that he had laying around the shop. Really thin material. His was so bad that the track starter rounded up a band, part of the planetary set, reverse ring gear, high gear clutch and the band...and bought it back to him while he was getting out of the truck. The only thing left was a converter, pump, and bellhousing. The rest was ON the track.
    I hate to hear of broken parts, and especially broken body parts but these things happen..too often. Hope you get that thing back up & running soon!
    ....with a blanket or trans shield of some sort!
  4. Rick
    Rick G8I operations
    Ocala, Florida
    It was at Capitol, it sheared the ears off the starter and cracked up the bell housing pretty good as well. engine seemed to be running fine when I killed the fuel and shut it down I had to reach in the scoop to undo the rear air cleaner so I could open the hood I guess the hood shifted around. Pieces were flying up every where and my friends thought I hit the wall but I got it over pretty quick and by chance stopped right in front of the ambulance.
  5. eddie1975
    Martinsburg, WV
    sold
    yikes glad your alright...do you know where it started? what when wrong first?
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Very scarey, glad you are okay.
    Dan
  7. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Tranmission...you ARE the weakest link. Good-bye.
  8. Rick
    Rick G8I operations
    Ocala, Florida
    It happened as I crossed the finish line thats how I know how fast I was going I suspect the tranny just locked up and exploaded. I guess the rear must have sheared the drive shaft the reason I say this is the yoke for the drive shaft was still in the tranny with the ujoint cups still attached. By the way this was the heavy FMX, you got any C4's up in Martinsburg?
  9. don graham
    wow. Lots of parts there. Glad you didn't get hurt at all. :mad:
  10. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    glad no one was hurt....thats rough to look at.
  11. Old Guy
    Old Guy Member
    Dang! That is not good, glad you are in one piece. What RPM were you turning at the stripe?
  12. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Sorry to hear, glad you didn't get hurt. Performance Automatic near you is worth checking out! Good luck!
  13. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Man glad you are OK...Look at the bright side..you don't have to go back to the shop and say...gotta pull the trans. and see whats wrong with it!
  14. Rick
    Rick G8I operations
    Ocala, Florida
    I guess I was spinning close to 68 or 7k although my chip is set at 7k but I did'nt hit it. Prior to this I had future plans on replacing the FMX with a lighter C4 so the good news is it will come out pretty easy now since almost half is gone.
    :drive:
  15. Earl Branham
    Lugoff, SC
    Rick; glad you are ok. That sort of thing will check out the condition of your heart, real fast!
