Ordered my Rod & Custom front cross member...
Discussion in 'General Maverick/Comet' started by ATOMonkey, Jan 5, 2010.
  1. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Should be here some time this week. I'm as giddy as a school girl!
    Got the front end all chopped up and wire wheeled in anticipation.
    Everyone says the guys at R&C are good to work with and they are absolutely right. Very patient, knowledgable and good natured.
    I was going to make my own motor mounts until he tipped me off that it might make it difficult to mount the rack later if I didn't get them in the right place. So, my cross member will be welded in, for a manual rack, with 4.6L mounts, and set up for coil-overs.
    I'll have pics as soon as it comes in.
  2. maverick88tc
    maverick88tc Member
    athens tennessee
    73 maverick grabber stock 460 s475 turbo
    i just got done doing a full tilt street rods crossmember it wasn't that bad to do
  3. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    How did you measure where to install it?
  4. maverick88tc
    maverick88tc Member
    athens tennessee
    i put a board on the front of the framerails and measured back to the center of the wheels then took the suspension off and marked that measurement on the frame then once i got the crossmermber in i triple checked the measeurements top several different points
  5. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    R&C includes a dimension sheet for locating it...
  6. ModMav71
    ModMav71 Member
    Sebring, FL
    Man its about time. I bet you are excited! it will sure make fitting that dohc 4.6 alot easier. Im finishing up the firewall on mine. I grafted in a 97 Mustang Cobra firewall so everything like the pedals and a/c unit and all that bolt right up. Better take some pics
  7. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Super excited! Your project sounds pretty cool! I'm just going to smooth out the firewall. The only holes will be for the heater, and I'm going to try to hide those as best as I can.
  8. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Here are some pics. Like I said before, these people are just amazing to work with. It was less than a week between ordering the part and them getting it to my house. The instructions that came with the crossmember are very detailed, and the quality of the work is just outstanding.
    I should be able to start installing it this saturday. This morning we got a bunch of snow, so playing outside with my boy is number one priority for the next couple of days! :)
  9. Dave B
    Wow that was quick!
    Nice work!!
  10. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    I've already got plans to modify the engine frame mounts. I don't like the standard 4.6 engine mounts. They rely way too much on the rubber to hold the engine in the car. I'm going to modify some chevy clam shell mounts to use instead. Shouldn't be a real big deal. A couple extra holes here and there. Maybe some welding and viola!
    I don't think the Mark VIII mounts that came with the engine will work anyway.
  11. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    its a nice piece i have one but have shelved it for another solution!!!!:D
  12. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Did you buy the whole thing (a-arms, rack, spindles, etc.) or just the cross member?
  13. CornedBeef4.6L
    no longer here
    just the crossmember but bI plan on using it on a drag car later.....
  14. car-nut
    car-nut Glenn
    conn.
    I have mine installed now as well. They make a great product! I am amazed at how much the crossmember and engine mounts are for your engine.
    Good luck.
  15. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    The quality on that is amazing. I wouldn't even want to paint it and hide it under the engine, the welds are just too nice.
