Original exhaust manifold
Discussion in 'Cosmetic' started by 71nogo, Jun 4, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    What if anything can be done b4 install to dress them up? my motor is going to be painted, and i don't think there is a engine paint on the mkt that can withstand exh man heat. thank you in advance.
  2. justin has a 74
    kentucky
    Power coat them or get some 1000 degree exhaust paint.
  3. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    who carries that paint?
  4. Acornridgeman
    Wisconsin
    Plasti-kote makes a special manifold / header paint - comes in different colors. Cost is amazingly cheap at about $5 a can - enough to do 5 sets of manifolds. Rated to 1300 degrees.
    http://www.plastikote.com/products/Specialty/Hi-Temp-Paint.html
    Warning: It absolutely needs to be sprayed and then within a couple hours run on the engine to cure properly. The only other way to cure the coating, is in a 500 degree oven - and with the fumes it gives off when curing you do not want to do it in your kitchen. :cry:
  5. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    Thanks!!!:d my build is starting to come together thanks to guys.
