A few panels on my Light Blue 74 maverick have spots that are showing age and turning pale. I know they are oxidizing but i don't want to just Paint the car. anyone know of a product that can remedy this problem without needing to remove the panels?
Mothers has a product for removing oxidation some sort of "pre-wax" cleaner. You could also try the clay bar method or good old rubbing compound.If the oxidation is real bad you may have to wet sand the areas with 1500/2000 grit wet sanding paper...good luck!!!
