P/S Pump bolt
Discussion in 'Technical' started by dspr, Jun 12, 2009.
  1. dspr
    dspr Member
    Trondheim, Norway
    Well, seems that during the winter I've managed to have lost some small parts:oops:
    One of them, which is actually kinda important right now, is the small bolt that goes through the bottom hole of the p/s-pump and into the engine block(or maybe it was the water pump?.. haven't looked at it for a while:p)..
    So I guess I have replace it:oops:
    Anyways, does anyone here have info on the size, length and pitch of it? I think it's about an inch long or so?:hmmm:
  2. blugene
    blugene Senior member
    Did you contact mean_maverick? He has stuff like that.
  3. dspr
    dspr Member
    Trondheim, Norway
    Figured I'd just try to get near correct measurements on it, and get it brand new.. Wouldn't have to think about shipping etc(Shipping could easily jump up to 10-20$):p
  4. blugene
    Yea, I forgot where you are at
  5. dspr
    dspr Member
    Trondheim, Norway
    Yup:p
    But like I said, I think it was somewhere around an inch long and matches the threads in the engine block..
    Maybe someone that has P/S could unscrew the bolt from their car an take a pic or two? :)
  6. blugene
    I would if I had PS. What size motor and year? Pic of the area/hole your asking about?
  7. dspr
    dspr Member
    Trondheim, Norway
    '71 302:) It's the bolt that goes trough the adjustable bracket for the p/s pump actually:p
  8. blugene
    Hopefuly someone will chime in. Sometime today I will break out my cd of the breakdowns and see if it's in there.
  9. dspr
    dspr Member
    Trondheim, Norway
    CD? :hmmm:
  10. blugene
    My cd sucks. It has so much info you get lost. I found the illustration but it gives bolts in part #s not sizes. It's also 73-79.
  11. dspr
    dspr Member
    Trondheim, Norway
    Agreed, got kinda lost looking at it.. Really had to focus:p But it looks like there are two or three of that bolt I'm looking for on that setup. My setup will be kinda homemade, had to weld together and bend a custom adjustable bracket between the water pump and p/s pump..
    The one I'm looking for is the one going trough the adjustable bracket and into the non-adjustable bracket mounted directly on the p/s pump.. You can see it down and to the left on the picture :)
  12. blugene
    I bet it's the same as the ones that bolt the pump to the bracket. You could take one out and match it.
