Paint for engine bay
Discussion in 'Cosmetic' started by mrmalina99, Aug 21, 2012.
  1. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    What black paint do you use for your engine bay? I have a tried a a couple but I am not happy with the results.
    Dupli-Color Semi Gloss black - Too shiny
    VHT Header paint - Too flat
    I am trying to find something with a very light sheen but not quite flat black.
  2. John Holden
    John Holden Member
    NJ
    If you're asking about rattle cans, I like krylon semi flat.
  3. rthomas771
    Duplicolor DE 1635 is very close
  4. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Yes, rattle cans. I will check it out, thanks.
    This is the one that I used that seemed too glossy.
  5. John Holden
    John Holden Member
    NJ
    Unfortunately krylon recently changed their formula. The color is still the same but it's alot thinner now so you need more coats. It lays on nice though.
  6. Acornridgeman
    Wisconsin
    I know you want rattle can, but if you can at all get with somebody that has spray equipment - SEM Hot Rod Black is the coolest stuff in the world for coverage, durability, and most of all factory sheen. It is a catalyzed 2 part mix and comes in 1 quart kits complete with thinner.
  7. Craig Selvey
    Chassis Black from Eastwood.
  8. junrai
    junrai Member
    rancho cordova ca
    I went from a grease pit to a clean finish by sandblasting the engine bay and then hitting it with $1 cans of walmart flat black. I know you said you dont want flat black but this acts like a satin it has a small shine to it just enough to keep it from being chalky looking the dust in the second picture is from months of setting around in the garage it looks nice and clean when washed I also painted the whole car with it
  9. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I picked up 2 new shades tonight: Duplicolor low gloss black de1634 and krylon semi flat. The duplicator was close but a little flatter then I was hoping for, the krylon was perfect and that its what I am using.
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    VHT SP139 goes on well, has a nice satin finish and is very durable.....
  11. Joe Dirt
    Eastwood chassis black or rustoleom engine enamel in low gloss black
  12. bmcdaniel
    bmcdaniel Senile Member
    I used Rustoleum Satin Black.
  13. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Painted Engine Bay today decided to take it back to black like factory
    Used the HVT SP139
    71gold and jasonwthompson like this.
  14. Krazy Comet
    You can use any color you like but Ford painted engine bays either body color or semi gloss black... Which depends on year and assembly plant...
  15. 71maverick361
    Odem
    71 Grabber
    It is a satin black
