Paint to look like vinyl top.
Discussion in 'Cosmetic' started by rwbrooks50, Sep 29, 2009.
  1. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
    My 72 Grabber had a vinyl top. I want paint to look like vinyl. Will hammered paint be the best?
    Rick
    Forney, TX
  2. Mavman72
    No since it is a multi toned(colored) paint.If you use it as a base for texture purposes only..."Maybe" it will look ok when topcoated.
  3. mean_maverick
    rubber bed liner stuff comes to mind....
    or just go smooth for that classy look, like i did :cool:
  4. Joe Dirt
    chip guard
  5. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    3M makes a real good one X2
    brad:)
  6. will8069
    will8069 Member
    Garland, TX
    1974 Comet 250 straight 6
    where do you find chip guard?
  7. rwbrooks50
    Forney Texas
    Chip Guard
    The chip guard by 3M and others is a protective film. I am looking for a paint.
    Maybe a roll on bedliner kit would work.
    Rick
  8. 1973Maverick357
    Cookeville TN
  9. Joe Dirt
  10. rwbrooks50
    Forney Texas
    I am going to try the roll on bedliner. I need to find it in a tan or saddle color.
    I'll take pictures of the process and final product. I need to repair some small dents first.
    Thanks for the info.
    Rick
  11. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I think you need something that is top coated. All of the bedliner stuff I have seen seems to fade over a year or two. Maybe some of the higher cost spray in stuff doesn't but I have seen pleny of trucks in parking lost with what looked like spray in liner that had a dull look to it.
    clint
  12. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    All of it does, it's the nature of the beast. When I was working at a truck and trailer store, I helped do the research on the chemicals when the contract of the chemical supplier came due. Every one of the companies I checked with said the liner would fade, but different chemicals take longer than others to fade.
    -Scott H.
  13. rwbrooks50
    Forney Texas
  14. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Good luck with your project, Rick.
    For anyone's information, here are close-up pictures of the Herculiner coating (used in the other thread) and of an actual vinyl top.
    I don't think the Herculiner is going to fool anyone from up-close, but if you aren't trying to fool anyone into thinking it's vinyl, then no worries.
    Herucliner:
    Vinyl:
  15. rwbrooks50
    Forney Texas
    Rick, thanks for the close up pictures. I just want a textured look, not smooth. Since the car had a vinyl top original.
    I'll try both application to see which, I like best.
    Rick
