Parking Brake Cable Route
Discussion in 'Technical' started by Tony302, Nov 18, 2020.
Tags:
  1. Tony302
    Tony302 Member
    2047 ramelli ave ventura ca 93003
    Dose anyone have a picture of the layout of the parking brake cable inside the driver compartment. I'm working on my 1972 Grabber.
    Tony
  2. Craig Selvey
    Pretty simple. It comes up through the hole in the firewall and goes directly into the parking brake pull handle.
  3. Tony302
    Tony302 Member
    Hi, could you tell me the location of the hole. The parking brake handle and pulley are still mounted. The floor was painted with truck bed liner so there are no visible holes .
    Thanks
    Tony
  4. Craig Selvey
    The hole is just below the pulley for the brake handle. The hole is sort of parallel and horizontal to the ground, not vertical like the firewall.
  5. Tony302
    Tony302 Member
    Thanks for the info. I found it
    Tony
    Craig Selvey likes this.
  6. Tony302
    Tony302 Member
    Hi, can somebody tell me which side the long brake cable goes on
    Thanks Tony
  7. rthomas771
    Long cable goes on driver's side
    71gold likes this.
  8. Tony302
    Tony302 Member
    Thanks
    Tony
  9. Craig Selvey
    Yep....long on the driver's side.
    My crude diagram
  10. Tony302
    Tony302 Member
    How and where dose the cable clips attach ? It looks like it is a push in. 2 clips came with the cable that hooks up the parking brake handle.
    Tony
  11. Craig Selvey
    The clips fit into a recess on the cable outer sheeting. There is a metal area that is recessed that takes the clips.
  12. Tony302
    Tony302 Member
    Hi can you tell me if the cable goes over the pulley or under?
    Tony
  13. Craig Selvey
    If you are asking about the pulley on the handle inside the car....it goes over the pulley.
  14. Tony302
    Tony302 Member
    Hey thanks I will give it a try tomorrow
    Tony
