Pcv 101
Discussion in 'General Maverick/Comet' started by BIG T, Mar 6, 2014.
  1. BIG T
    BIG T Member
    Ventura Ca.
    Hello, need a little help, My engine looks like I'm driving with the valve covers off. It is blowing oil out the dip stick tube, around the PCV and the breather. This just started around 2 week ago. I have the PCV hook up to the PCV port on my 670 holley. I have been driving this combo for about 4 years. I have change the PCV with no change. I had my 69 heads done about 4 years ago. :thumbs2:
    Tony
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Do you have any vacuum present at the PCV port?
  3. John Holden
    John Holden Member
    NJ
    Any other symptoms? And as bkelley said, make sure you actually have vacuum on the PCV valve hose. Start there.
  4. Moneymaker 1
    Panama City Florida
    Agreed ^^^^ mine became plugged and started smoking like you describe, changed it and all is well again.
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Might want to do a compression test. Too much blow by from worn out piston rings will cause excessive crankcase pressure and push it out anywhere it can go. Good luck and hope its something simple.
  6. darren
    VAcuum at the valve? PCV Breather not plugged up? You need fresh air coming in.
    IF the PCV system is OK your looking at blow by.
  7. 71gold
    is the crank case breather stopped up?
  8. Krazy Comet
    If it's puffing badly from PCV fresh air supply(usually in air cleaner), dipstick tube and oil fill all at same time, you have a serious blowby issue...
  9. BIG T
    BIG T Member
    Ventura Ca.
    Thanks everybody, I'm pulling the 302. I will kept you posted.
    Tony
