pertronix
Discussion in 'New Members Forum' started by BEAVERMAV, Nov 19, 2016.
  1. BEAVERMAV
    BEAVERMAV Member
    Beaver Falls, PA
    1974 Ford Maverick, 4 door, 250 6cyl.
    how do i know what pertronix kit i need for my 74, 6cyl, 250cuin
  2. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    The Petronix website suggests looking at the base of your distributor or an attached tag for codes. Then go back to the website and plug the codes into their search feature. Let us know if that worked.
    MD
  3. 71gold
    it will need a points style dist. to start with for a kit,
    or you can get the pertronix dist.
  4. 73curtis
    73curtis Member
    ohio
    I used there conversion on a 200 and it worked great , also on some older chevys , great prouducts
  5. Acornridgeman
    Wisconsin
    1261 is the common Ford 6 cylinder kit for stock point distributors in the Maverick - 70 to 74.
    I put Pertronix in everything .......... :)
  6. 71gold
    had them in everything also...ford 6/8 cyl...chevy 6/8 cyl...VWs and more than one Harley ...:yup:
  7. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    used these in my 250, the box said they will work on all small I6's. IMG_0412.PNG
  8. BEAVERMAV
    BEAVERMAV Member
    Beaver Falls, PA
    Thank you
  9. rthomas771
    I learned the hard way that the 1261 doesn't fit the 1960-64 distributor with the "D" style shaft. Part number for this type shaft is 1266.
