pics of v8 with brake booster
Discussion in 'General Maverick/Comet' started by spdracr301, Feb 7, 2016.
  1. spdracr301
    spdracr301 Member
    Franklin NC
    1976 maverick
    does anyone have some under hood pics of a mav with a V8 and power brake booster
    just trying to get an idea how my 302 is going to fit
  2. Craig Selvey
    Here you go. It fits.
    spdracr301 likes this.
  3. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Has anyone tried this with a Fuel injected intake on it? Fit, no fit?
  4. 55crownvic
    55crownvic Member
    colorado springs
    dont know, but this may be of help
    Crazy Larry likes this.
  5. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Those are nice, the previous owner made something similar, but not as effective. Basically round bar stock hammered flat on both ends and bolted in...
  6. garry kilgore
    garry kilgore maverick 2
    ga.
    1972 maverick
    what did brake booster & master cylinder come off
  7. 55crownvic
    55crownvic Member
    colorado springs
    the booster is a 7" one from ebay, aftermarket, streetrod style. The M/C is from a 89 mustang. Turns out I didnt like how the M/C worked and replaced it with an original style.
  8. mojo
    The OE MC provided better braking than the Stang MC? Did u have to modify the pushrod and what effect did it have on the brake sw activation?
  9. 55crownvic
    55crownvic Member
    colorado springs
    The aftermarket booster comes with a threaded rod, I add a threaded nut with about 2" of the original rod welded to that nut. Thats the pedal heigth adjustment.
    stumanchu and mojo like this.
  10. mojo
    Thanks for the pic! U have better results w/ the OE type mc? How much clearance between the end of the mc and the shock tower? Used the OE prop. valve? 4 whl disk on the car? This is something I need to take a serious look at!
  11. 55crownvic
    55crownvic Member
    colorado springs
    Everett.....I couldnt get a satisfactory pedal feel with the mustang MC, I would have to raise the pedal to a height that was hard for me to get my foot to, it just took to much pedal to get the car to stop. I love the looks of that mustang MC but it didnt work for me, I went back to the factory MC and all is good, must be a different diameter between the MC'ers. My car has the maverick disc on front and drum on the rear, and I am using the stock 4-wheel drum proportioning valve, I like how it works now. There is a little more than 1/4" between the shock tower and the MC.
  12. stumanchu
    stumanchu Stuart
    Portland, OR
    I think I will go this route. Use my current manual brake pedal, fit one of those 7" boosters, and buy a new MC. Then if I want to install an export brace, no problem. No need to hunt down some factory gizmos...use what I got and be done. Thank you!
  13. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I think that's a good plan. The factory power brake set up was an afterthought anyway. There are better options available now.
  14. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
  15. 55crownvic
    55crownvic Member
    colorado springs
    Yep, thats it. Yes, new holes need drilled, inside on the pedal support as well. Its kinda a pita but well worth the effort.
