Picture request....power brake booster fitment
Discussion in 'General Maverick/Comet' started by car-nut, Jun 26, 2011.
  1. car-nut
    car-nut Glenn
    conn.
    Picture request....power brake booster.
    Hey guys, I am hoping some of you would be so kind as to post a picture or two of your power brake booster and your V8? I am in the process of some power brake mock up and don't have the engine in the car to check fitment. How big of a booster will fit with a 302? A 7", 8" or 9"?
    Show me what you have please?
    Glenn
  2. Craig Selvey
    Are you wanting the FACTORY set-up?
  3. maverick75
    The factory setup cleared my 302 fine, even with tall valve covers. It is tilted up, I don't know if that is to make more room or what.
  4. car-nut
    car-nut Glenn
    conn.
    No Craig I am going with an aftermarket unit. Thanks for the picture. I am trying to see what some of you guys have done, what fits and what doesn't.
  5. Dave B
    Not a lot of aftermarket boosters going in, there was someone that bought one and installed it (I can't remember who, it was awhile ago) Some of the Falcon guys have used Geo Metro boosters, and there were some sites, I'll see what I've saved.
  6. mojo
    Check w/ "mavdog71", on this forum, he uses an aftermarket booster frm www.Abspowerbake.com. I think its an 8" used on 60-66 Falcon/Ranchero. I believe the pt # is 9782-PB2. Also, u can contact the company. If I recall, he was not able to/ or did'nt use the tower support after installion. I believe he has some pix of it in his gallery. Hope this helps.
    IMG_0393_thumb.jpg MG]
  7. 55crownvic
    55crownvic Member
    colorado springs
    I have an aftermarket 7" single diaphram booster with the stock M/C in my mav. Dont have a pic, but will get one to you tommorrow, hopefully. I bought it from ebay, heres a link to a similar unit, http://cgi.ebay.com/ebaymotors/7-ST...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Mods are needed to get it to fit the firewall but not too serious, plus it works great and fits in the space, and am using the non-booster tower braces
  8. CaptainComet
    If the car is going to have power steering, hydroboost brake MC setups are pretty compact, too. No big booster needed, just a couple lines from the PS pump. (y)
  9. 55crownvic
    55crownvic Member
    colorado springs
    heres a few.....
  10. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Thats a nice setup. are you using the manual brake pedal assembly? What did you do for the pedal rod?
  11. 55crownvic
    55crownvic Member
    colorado springs
    Yes, manual brake pedal.
    Once the booster is mounted, I cut the rod and welded it to a threaded nut that screws onto the booster shaft, pretty simple. The hardest part of the setup was to remove the pedal support and notch a place for two of the booster bolts, so I could get to it and install the nuts to them. Those were the bolts that originally mounted the m/c to.
  12. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Hay nuts
    Yes I used the booster from ABS Power Brakes in Orange ca .. The fit looks better than factory . About 1/2'' behind spring tower .
    Things need to know when ordering the booster.
    Mounting studs need to be 2 3/8'' to 2 1/2'' long.
    Stock mounting studs removed and drilled out to 3/8'' or larger
    Push rod opening in fire wall need to be opened up about 3/16''
    Good luck booster and master works great..
    Jay
  13. mojo
    Did u use the manual pedal assembly w/ the PB setup?
  14. flynbrd
    flynbrd Member
  15. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Mojo
    My car had manual brakes and I used that pedal ..
