PINKY's LIST
Discussion in 'Drag Racing' started by PINKY, May 18, 2006.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Cam Lunati 51019LUN 248/256 .389/.389 108 lobe separation
    Lunati lifters
    Rocker arms (Lunati)
    Pushrods (Trick Flow)
    Valves (REV)
    Valve seals are Manley viton material
    Main bearings, coated bearings from Calico,
    Rod Bearings, coated from Calico
    Cam bearings, coated from Calico
    New timing chain and gears. (Trick Flow)
    Thrust bearing with needle rollers, Comp Cams
    Piston rings from JE,
    oil ring support rail
    spiralox
    Polish crankshaft
    Fly cut pistons
    etc. etc. etc. :rolleyes:
    I hope to have it back up and running by late June:huh:
    I know Doc has done a lot of work on it already.
    We shall see :)
  2. Mavaholic
    All this stuff needed or just updating things?
  3. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Its a little of both.
    Some of it is "while we are here" :)
  4. don graham
    i thought this might be a list of who pinky is going after. was wondering if i was on the list.:evilsmile
  5. riporter
    riporter Member
    Charleston S.C.
    Oh. he's gonna definitely need it:29:
    Sounds like the Doc is fixin you up right, I might oughta get some "plumbing" done...just in case.:D
  6. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Don....thats a seperate "special" list :evilsmile
    Rick, you have nothing to worry about, my little tire car has no chance of beating the PLUMSTER :tsk: but we should get some pretty pictures of them at the starting line :)
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    John, I hope you get it done. The whole reason I am going this year is to see the champ beaten by the Plumster:D .......well that and so I can here Ron say "eh":yup:
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I have not doubt you know what your are doing, but would you please explain the cam selection (small lift in particular)? I realize getting the most out of an engine is done by the "system" approach. I assume this works well with your setup.
    news bulletin: I just checked the specs on the Lunati 51019LUN from summitracing.com:
    Lunati Solid Roller Tappet Camshafts
    Camshaft, Solid Roller Tappet, Advertised Duration 281/ 289, Lift .602/ .602
    :huh:
  9. don graham
    i was trying to be nice about the cam. i noticed it too. figured he was trying to lay some smack. i was thinking that has to be one smoooooth idle. thanks for mentioning it rick.:rofl2:
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    no need to be nice Don :evilsmile thats not the norm around here :biglaugh:
    I have no ideal about the cam, other than that is what Doc says will work best with my set-up. I know Doc mentioned about having the exhaust side stay open a little longer to help my small headers :) but other than that it is real similar to the cam I had in it before.
    I trust whatever Doc says...... :yup:
    I know I expressed to Doc that I am really wanting something that is more reliable.....if I lose a couple numbers......well then I do. I am willing to sacrafice a little performance for a little more longivity.
    Maybe Doc will get on here and add more to it.
  11. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    the lift on that cam is probley auctal lobe lift , .602/.602 is valve lift w/ 1.6 rockers .389 is lobe lift at cam , i believe this is true if i am wrong sorry im pretty sure thats what it is, mutilply 389 x 1.6 and you should get 602 sounds good though(y)
  12. Mavaholic
    Speaking of Doc, is he comming this year?
  13. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    No, they are moving to Dallas, TX. in July.
  14. Rick Book
    Rick Book Member
    Thailand
    Shows you how much I know about cams. I've never heard anyone describe a cam that way.
  15. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    That sure is a nice combo John. I dont know what the innards were before but if the cam is smaller it should make for a more user friendly street car. But with some good tuning you might not lose any E.T.
    Dan
    ps what heads are on it?
