Pinto front end?
Discussion in 'Technical' started by gmatthew76, Dec 30, 2011.
  1. gmatthew76
    gmatthew76 Member
    Freeport, Fl
    1976 2 dr Maverick, 1977 2dr Maverick,1998 Ranger, 2004 Focus Wagon
    I've been in contact with a fellow that wants to sell me his 71 Maverick project. The car is in pieces but supposedly rust free. He's grafted a Pinto front end on it, although I don't like the angle of the steering rod. Here's the pics he sent me of the car. He says he has all the parts in box's. What do you guys think?
    :tiphat:
  2. maverick75
    Doesn't look that bad(the front end), but the pictures are low quality so I cant see how the welds are.
    Pinto front end was one of the things guys did before they made aftermarket MII kits.
    The steering angle looks correctable by shortening the shaft.
    If you're looking for a drag car project it could be worth it, restoring it would be another story.... Body looks like it has rust in the rear quarters, lower doors and front lower fender area.
  3. Resto
    Resto Benders Evil Twin
    Yuma AZ
    My 2 cents? I would never buy a project from anyone. It is like a box of chocolates....:)
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Only thing I see it could use is a support bearing on the angled shaft. Any Mustang II/ Pinto rack conversion would probably look about the same. As long as those are the U joints and shafts sold for steering, and not some hardware store stuff for a farm implement, they should be fine.
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Pinto was the hot setup in the early 80's. Basically just lightweight Mustang II parts.
  6. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Steering shafts can be corrected. From the pictures it looks like a clean fit. If its a good deal for you Remember you can always make it better.
  7. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    mII steering shafts look like that. If you can get it for a good deal and feel like doing a project, i say go for it.
  8. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    As Alex said, cut the stock steering shaft back so only about 2" protrudes through the firewall, then build a longer intermediate shaft.
