pitman arm hitting the header
Discussion in 'Technical' started by inline6, Mar 5, 2006.
  1. inline6
    inline6 Member
    anyone else running a 302 with hooker 6901 headers,w/o power steering,and floor shift?i noticed i have a dent in one of my tubes,(driver side)thought it felt like something was hitting/binding,when i turned.anyone have a pic of their pitman arm,or the correct one for non power steering cars they could post?maybe i'm using the wrong one.thank you...chuck.
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Chuck,, I have the same setup, but I know the late model cars have a different combo of front end parts. You may have to buy the idler arm that has a drop to it from my memory.
    Dan
  3. inline6
    inline6 Member
    thanks for the response dan,but i'm lost:confused: how would the idler arm help drop the pitman arm?:hmmm:
  4. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    they do hit on some on left turn...mine hit i fig it was the 351 swap why i had the tube redent
  5. Dan Starnes
    West Central IL
    Dunno chuck,, does the drop change the geometry of everything? I am going on memory here from what I went thru 31 years ago with my first Maverick.
    Dan
  6. MaverickGrabber
    Cardington, ohio
    well if the pitman arm is hitting the pipe its mounted to the gear box and the idler cant change where the pitman arm mounts to the box ….
  7. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    Welp, that's it !! Guess you're gonna have to park it and quite worrying about me blowing your doors off !!! Although, I guess you just need to drive straight for me to beat you !!:bananaman:biglaugh::rofl2: You could always bring the headers here, I'll bring some stock home and we can make our own. Just a thought.
  8. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I'm at the same road block, the pipe hits, hard. I cut out the offending piece and am going to midas this afternoon to see if they can re work the pipe. Good luck
  9. scooper77515
    When I bought mine, they were already dented just a little, and I have the P/S drop bracket, and not even close to hitting anything. But that is on a P/S car, might be different on a nonP/S car.
  10. courier11sec
    courier11sec Member
    Tucson, AZ
    Same thing on mine. only fitment problem with 6901's as far as I know. I just welded a couple of pieces of round rod to the existing steering stop. no more hitting, just can't turn all the way.
  11. scooper77515
    6901s are the BOMB!!! Just pound them out a bit, and they fit just fine!
    Sad to say that nobody makes a direct fit for Mav/Comets!
  12. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    I couldn't get mine to steer to the left at all, dunno why, but midas is gonna try to re work the offending pipe for me, hopefully get it way out of the way.
  13. inline6
    inline6 Member
    scooper,how much did you have to pound them in?right now i have a dent on my one tube,about the size of a dime.(from the pitman arm)my buddy,dave(maverickgrabber)had an idea to heat the one pipe up cherry red and pry it out about a half -/3/4 inch.:huh:
  14. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    My 6901's required no modifications in my 71 with manual steering.
  15. inline6
    inline6 Member
    makes me wonder,since these headers were so mass produced,maybe their qc department wasn't that good?maybe some left the factory,a little bit out of spec/tolerence.i've heard of people having fitment issues and some not.
