Please assist in indentifying this carb gasket
Discussion in 'Technical' started by canuck222, May 11, 2011.
  1. canuck222
    canuck222 vroom, vroom... Supporting Member
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    Please assist in identifying this carb gasket
    The rebuild of my 2100 carb is almost complete, however I am having difficulty identifying and locating a replacement gasket as noted in the image below located between the EGR spacer and the intake manifold. Can someone please tell me the name of the gasket and a part number?
  2. Dave B
    I might have one, I have to go to the school tonight, to see my daughter in something, but I can look once I get home.
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
  4. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Th eone I linked has an EGR hole on both sides, thats probably to be more uniform for other vehicles too. Dosnt matter though because the hole youdont need will be blocked. And there is extra material on the sides between the mountin holes so it looks a little different. But theis is the standard 2 bbl carb gasket with EGR holes. Use that Fel-Pro part number to order or pick up from whatever part store you like.
  5. baddad457
    If your local parts house is anything like mine, they'll just let you go back there and find the gasket you're looking for. The parts house I deal with all know me from years of doing business with em and they have no problem with me digging thru their stock to find what I want without bothering them.
