please help I'm going nuts
Discussion in 'Technical' started by calicomet, Jul 9, 2006.
  1. calicomet
    calicomet New Member
    ventura california
    73 comet
    :huh:I have a 73 comet 6 cyl I bought it from the guy that got it from the original owner it has 88k on it.
    he had replaced the carb and the tranny
    it never has run quite right kind of likev a battle against it self
    it has a one barrel-- now when it got worse and I started checking around I found the carb was lose and in transfering a valve from the old to the new he put this thing together sideways :yikes:
    after reading the hayes book I am now under the impresion there is some kind of a govener in between the transmission and the carb:(
    I am confused as hell when it was running and I got it out on the highway it ran great ./ any ideas
    also the shifter does not work quite right when in park sometimes it will slide:eek:
    help please calicomet
  2. blugene
    Linkage bushings or gromets? Not sure, I have an 8 cyl. Wait around, someone will help you soon. Oh yea...:Welcome:
  3. calicomet
    ventura california
    73 comet
    thanx gene
  4. Mavaholic
    There is no governor between the carb and transmission. There is a rod, but its sole purpose is to kick the transmission down to second gear when the gas pedal is floored for passing.
    On the shifter question, There is an adjustment down on the transmission arm, where the linkage connects to it, Easiest way is to loosen it, manually put the shifter and transmission arm in neutral, then tighten it back up.
  5. calicomet
    ventura california
    73 comet
    thanx mav
    hey I 've been given a 2 barrel of a 302 any ideas how I can make this work?
  6. Mavaholic
    Not really. I have seen adapters to put a 2 bbl on a 1 bbl manifold but I have no personal experience to go by.
  7. Texas 71
    Texas 71 Member
    Orange,Tx.
    O.K. Loose carb usually equals major vacuum leak. This will be a big problem for keeping the car idleing well if it runs at all. Mavaholic is right on the tranny rod, it is an "S" shape and follows the top of the transmission down. As for putting it together sideways I'm not sure what is meant by that.
  8. ModMav71
    ModMav71 Member
    Sebring, FL
    Check out Fordsix.com they got plenty of info on there about the Ford inline six engine.
  9. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    An aging c4 is notorious for sliping out of park without warning. I assume in makes a clunking sound as it rolls back? I believe it is something internal (I'm no automatic expert, by any means). Mine does the same thing.
    Your in Ventura, eh? I will be organizing a bbq at my place sometime in sept. your invited, we'll keep in touch(y) . I'm in Berdoo. Jamie
