Points to Duraspark wiring swap
Discussion in 'Technical' started by jasonwthompson, Nov 4, 2015.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I have access to a 75 302 Maverick with factory Duraspark distributor, module and wiring. Can the under-hood harness be removed from the 75 and connected to my 72 at the firewall without cutting and splicing and be expected to work?
  2. Krazy Comet
    Nope the pinout is entirely different, don't believe they'd even connect together...
  3. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    jasonwthompson likes this.
  4. yellow75
    Tillamook Oregon
    Not hard to due and worth it
  5. kzm0st
    kzm0st Member
    1967 mustang 1983 v8 ranger
    Mustang steve has conversion to dura spark schmatic
  6. Hotrock
    Munroe Falls, Ohio
    You will need to cut and splice. But get as much of the harness for the module, dizzy and coil collar as possible. I've attached a couple of schematics. Hope this helps.
  7. jasonwthompson
    Carrollton TX
    Thanks guys, got her done. Pulled all the harness from the donor and only had to connect 4 wires to the existing harness. I had forgotten how much points suck.
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    My '73 was converted to the Duraspark. It works great, but if I had it to do over, I'd go with a Pertronix conversion.
    71gold and mojo like this.
  9. jasonwthompson
    Carrollton TX
    That is what I would have done if I had not had a complete system available already.
