Polished headlight door
Discussion in 'Cosmetic' started by wardf, Mar 31, 2003.
  1. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    This is what my headlight doors look like. I really like the look, I had the hood strip polished also. I'm going to attempt to build a billet grill, I think all the polish will go great together.
  2. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    OK.how much did it cost You to have tnem polished?
  3. Mavaholic
    That looks pretty sharp. With a chromed grill it would really stand out. I had thought about making a cheap tub grill by making a frame and then using 3/8 steel tubing to make horizontal bars and weld them to the frame. You could use brake lines which are fairly cheap. Then get it chromed when I was done. I'll waite to see yours first.
  4. AdsMav
    AdsMav Member
    Ontario Canada
    1976 Maverick
  5. Mavaholic
    Not too bad but I want smaller tubes and much closer together.
  6. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    I know that was along time ago but I can't believe they even made a grill for a mav. I have agree with you Mavahlic, I'm hoping to have as many slats and about as wide as the horizontal in the original grill, but I want them to reach all the way to the headlight doors.
    Tom, they cost $15 per door.
  7. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    That looks really great!! I can't wait to see it on the car along with your grill!
    -Corbin
  8. AdsMav
    AdsMav Member
    Ontario Canada
    1976 Maverick
    I agree the bars should be thin and close together. I like the brake line idea. What if you made a frame from stainless steel, used stainless steel brake lines, weld it, then polish it. You won't have to worry about rust or a shotty chrome job? Just a thought.
  9. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Howz about chromed or anodized aluminum?
    I like the horizontal idea but I think the grill needs more smaller ribs.
    One could take say, 1/2" X ~.09 THK aluminum flat bar. Lay the plates flat and attach it to a frame (riveted or welded).
    Anodize or chrome the Al (if possible??).
    Just a thought.
