Por15
Discussion in 'Cosmetic' started by mavv, Mar 17, 2014.
  1. mavv
    mavv Member
    Miami FL
    maverick
    Hi guys
    To use por15 I need use some sand? wet? what grit?
    thanks
  2. rthomas771
    Just scrape the loose rust off and go at it
  3. mercgt73
    mercgt73 Member
    Wire brush or wire wheel will make quick work of it, no need for sand paper. (y)
  4. Dave B
    But follow their instructions, use Marine Clean, and Prep & Ready, to pre-treat the areas.
  5. 71gold
  6. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    Don't get the POR15 on your hand. It works real good on them.It has to wear off. :rofl2:
  7. Dave B
    I got it on my face....:rolleyes:
  8. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    A friend of mine told me it takes about a month to wear off your hands if you don`t wear gloves.NASTY
  9. 71gold
    I peeled it off one of my floor pans like a sheet of notebook paper...maybe the Guy at the restoration shop skipped one or more of the steps. I think there are at least three...:huh:
    those extra steps are why I use Rust Bullet...:yup:
  10. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    I didn't use the first stuff your supposed to put down and it can peel up easy if the surface wasnt rough enough. happened on my spots where it was brand new sheet metal, like trunk drops ect.
    and if it gets on your hands..usually wears off in 2 weeks..thats if you work with your hands lol. otherwise maybe longer.
  11. 71gold
    that's what I like about Rust Bullet, I can put it on new or old metal without it peeling. I've use it on new gas tanks 3-4 times with no problems. then black them out with the paint/undercoating.
      File size:
      124.7 KB
      32
      File size:
      85.4 KB
      30
  12. mavv
    mavv Member
    Miami FL
    maverick
    Hi
    To prep the area can I use sand? what sand? grit?
    thanks
  13. Dave B
  14. blugene
  15. Dave B
    That's the instructions, I've followed what they said, and have no issues. The underside of my Green car has been done almost 7 years now, I've driven it in some nasty weather, and its still where I put it. I don't see why people come up with their own application instructions, then bitch when the product fails.
