Possible engine problem?? Maybe. Not sure
Discussion in 'General Maverick/Comet' started by Chief1010, Feb 23, 2016.
  1. Chief1010
    Chief1010 Member
    Kentucky
    72 Maverick 306, 351W heads.. 75 Maverick ( parts car )... 71 Maverick ( in storage ).. 71 Torino 500 ,306, TCI Trans, Detroit Locker..
    I have a 302 ( has maybe 50 miles on motor ). I'm running royal purple 10w40 oil.. Took a breather cap off today as found this.. I'm running antifreeze and I know that's not antifreeze in the oil base.. It stay's in my garage.. I called a royal purple rep thinking it might be condensation.. I sent him the pics, and say's it's straight water.. He said that if the car hasn't been out in the rain then somebody had to put water in it.. I really hate to think somebody would do that.. If that is the case, they must not value there life very much at all.. Just wondering if anybody else has had this issue.. Thanks again.. image.jpeg image.jpeg image.jpeg image.jpeg
  2. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Only sure fire way to be sure is to drain the oil into a clean pan and see what it looks like...if someone dumped water in there you'd have two separate liquids come out....hopefully that's not the case
    how long has the car been sitting? I had a very similar buildup on the oil fill cap, the car had sat for quite a while though, and the oil was old, but since it's not run much at all I could see that happening. If you start it and stop it often, with little drive time, water will never have the chance to evaporate out of the engine oil.
  3. Krazy Comet
    Looks like cold weather condensation to me, if oil isn't milky I'll say not a problem... This issue develops if engine isn't run long enough to fully warm and evaporate it off... I try not to start my stuff this time of year unless I'm going to run it for at least 30 minutes...
    rotorr22 likes this.
  4. Chief1010
    Chief1010 Member
    Kentucky
    Just got done draining the oil.. There was about a half gallon of water, then alittle gray stuff then the oil... Good grief..
  5. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    If the water was there last time you ran it, I think all your oil would be milky. I am a Ford v8 newb.....does water flow through any part of the intake manifold that could leak into the lifter galley?
  7. 71gold
    several ways for water to get into oil...:yup:
    was it straight water.
  8. Chief1010
    Chief1010 Member
    Kentucky
    I wouldn't be as surprised that water is in the oil if I was running water.. But I'm running antifreeze..
  9. Chief1010
    Chief1010 Member
    Kentucky
    Yes straight water..
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    Refill oil and see if you get more water?
  11. 71gold
    what does the radiator level look like, that much water it should be almost empty.
  12. rthomas771
    Yes. That's why you use sealer around the water jackets on the intake manifold. If the heads are shaved a lot you need to shave the intake also
  13. Chief1010
    Chief1010 Member
    Kentucky
    My radiator level is full. It hasn't changed.. Having they much water in it is why I have the thought somebody put water in it.. The antifreeze in the radiator is full..
  14. Krazy Comet
    Are you using a PCV system???
  15. z28th1s
    Lynchburg, VA
    What was the total amount of fluid that came out of the oil pan? If it is more than what the oil capacity is minus what is in the oil filter then I would say something was added to the motor.
