Possible Trans Problem
Discussion in 'Technical' started by KitKat, Jan 7, 2011.
  1. KitKat
    KitKat Member
    1971 Comet
    I have a 71 Comet with a 302 and C4. Whenever it is put in gear the rpms drop considerably and i also have problems with it almost stalling during acceleration or going up hills. It has recently been leaking a good amount of trans fluid. Any ideas?
  2. Dave B
    Where's it leaking from?
  3. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    sounds like your converter is shot
  4. PaulS
    Kitkat,
    First - make sure the fluid level is between the ADD and FULL marks with the engine idling in Park.
    Does the transmission down-shift when you go up a hill? (passing gear)
    When is it leaking and how much are you having to add to keep it full?
    Does it accelerate from a stop OK?
  5. KitKat
    KitKat Member
    1971 Comet
    It is leaking whenever the car is off. Im not very familiar with trannys but it appears like its leaking somewhere in the middle of the trans, if that helps. A pretty good amount has to be added to keep it full after sitting over night there is about a four inch wide little puddle of trans fluid on the ground. It doesnt seem like it wants to down shift at any time, especially going up hills. And when you try to accelerate hard from a stop the car hesitates to the point where it almost cuts off, then it comes back and goes fine.
  6. strokermaverick
    strokermaverick Member
    Kitkat, PaulS is a c-4 transmission specialist. You can listen to him with confidence. I just thought I would let you in on that little bit of information.:)
  7. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    Make sure you are not overfilling the transmission. A four inch wide puddle shouldn't require "A pretty good amount" overnite. Are you checking the fluid level with the engine running?
  8. KitKat
    KitKat Member
    1971 Comet
    Yes i am checking it with the engine running. a pretty good amount was a bit of an overstatement. but recently after the car had been sitting for a few weeks i started it up and checked the tranny fluid to find nothing on the dipstick
  9. PaulS
    OK, a 4" wide puddle is about a teaspoon or so but we can talk about that in a bit. You are losing oil somewhere at a much faster rate than what is showing up on the floor - probably while driving. You are going to need to fix the downshift linkage. There should be a rod from the carb to the driver's side of the transmission where there should be a lever that pivots on the transmissions shift lever. With the throttle held wide open (full throttle, engine OFF) and with the downshift linkage fully depressed down toward the transmission there should be no more than .060" fre play between the linkage at the carb and the lever that actuates the rod - there is a screw to adjust it. The clearance has to be less that 1/16" and the less it is the better it is as long as it doesn't keep the throttle from opening all the way. This linkage and adjustment will make a world of difference in the way your car feels but more importantly your C4 will last longer too.
