Possible Transmission Problems
Discussion in 'Technical' started by will8069, Aug 2, 2010.
  1. will8069
    will8069 Member
    Garland, TX
    1974 Comet 250 straight 6
    So I drove my car for the first time in a while, because I just finished the paint job and replaced the carb. It started up just fine, went off as normal, but when it hit around 35-40 mph it didnt shift into second gear. It still kept going past it, to around 45, but I felt it was pushing it so I let off the throttle. My immediate thoughts went to the carb, but it seemed to be getting fuel just fine.What could possibly be wrong?
  2. Stavro
    Petaluma, California
    1972 GRABBER ZRX1200r
    vacuum modulator hose fell off?
  3. will8069
    will8069 Member
    Garland, TX
    Oh thank jesus. I thought that I might have actually had a serious problem. Where is the vacuum modulator hose?
  4. Stavro
    If I'm correct, there should be a hose/steel line, from the intake/carb area to the rear of the transmission.
    It may have been knocked off down below while you were messing with the carb topside.
    I could be wrong.....:D
  5. Stavro
    Hey.......was that it?:D
