Power brake booster
Discussion in 'Technical' started by Swiz2588, May 29, 2013.
  1. Swiz2588
    Swiz2588 Member
    Edmonton, Alberta, Canada.
    1974 mercury comet, 1973 ford maverick grabber, 1975 ford maverick 4 door.
    Hey, anyone try putting a brake booster on there and drum brake comet/maverick? If so do I need to change anything else?
  2. patnic
    patnic Member
    georgia
    maverick 1976
    you will need to change the residual pressure vale and the wheel cylinders on the front because of the pressure difference. I recommend changing the front with spindles from a Granada or just buy them from stainless steel like I did. worked out great.
  3. rthomas771
    I think you will need to change the whole pedal assembly because of the angle of the booster along with the shock tower brace
  4. Craig Selvey
    Yes, you would need to change the inisde pedal support as well.
    Going with DISC brakes is a far easier, cost effective, and safer upgrade than putting a power booster on a drum brake car.
