Power Brake Conversion Issues
Discussion in 'Technical' started by vdvdvd, Feb 20, 2009.
  1. vdvdvd
    vdvdvd New Member
    Have a new booster, master, and bracket sitting in my dining room. I have a 71 comet ive been frankensteining for several years now and im so close to getting it on the road. Id like to put power brakes on it before i do tho. I found a thread that showed a picture of the hole that needs to be put in the firewall to allow the power brake pedal rod thro into the passenger compartment.... problem is that i dont have the proper pedal assy apparently. what pedal assy can i get to fit my needs (interchange) and where can i get one (ya got one). thanks for your time... sorry if im not putting this in the right place... having trouble navigating forum :(
  2. JDM_GUY
    JDM_GUY Member
    San Francisco
    73 Maverick 2 door coupe, 75 JDM celica coupe, 75 JDM celica liftback, 93 ford probe GT
    i just bought a power disk brake kit for my 73 mavey off of a 77 model. the person who sold me the whole kit has a rod that are still with the booster, i will post pictures of how they look when i get them on my project section... perhaps that should help ya out.
    or better buy a used booster from a donor car with the rod still on it...
  3. Mavman72
    You need a brake pedal from a power brake equipped Mav/Comet.The ratio/travel is different than a non power set up.You may be able to relocate the rod mount hole on your exhisting pedal if... you can get the correct measurement for the holes location on the pedal.I believe 75? and up Mavs/Comets had power brakes.
  4. nelson
    nelson Member
    va
    71 maverick grabber
    i have the pedal set up for the power brake set up i bought it off of ebay i was going to use it but changed my mind its for sale email me at steppinmaverick1@aol.com thanks
  5. vdvdvd
    vdvdvd New Member
    Cool but..
    k, finally got my parts in the mail but with no instructions. do i slot the upper or lower booster holes in the firewall? cant find the link to the awesome tech article i need. know its on this page somewhere... ne one can help... running out of day light!
  6. Craig Selvey
    It is a tech article by me if that helps.
