Power steering bracket fasteners
Discussion in 'Technical' started by FordCountry180, Jul 7, 2012.
  1. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
    Has anybody had this problem. 1970 maverick - There a 2 threaded anchors in the frame that secure the 3/8" bolts for the power steering cylinder bracket. They look like some type of snap-in anchors. I had one pull out of the frame. Just the threaded nut piece fell out, the other half of the anchor assembly is still stuck in the frame. How do I fix this? :hmmm:
    By searching the web a bit, I found out they are called rivet nuts. how do they work though, do they expand when you tighten them up?
  2. Dave B
    You use a special tool to insert them, it's kinda like a threaded rivet. Years ago I pulled them out on my 74, i drilled them out, and welded nuts in their place.
  3. FordCountry180
    Parkesburg, PA
    Thanks for the reply. I just came across this on a google search. I'm going to give it a try before I break out the welder. http://www.carolinarovers.info/croc-stuff/tips/259-make-your-own-rivnut-tool Let me know what you think.
  4. Tannersg1
    Tannersg1 Member
    Classified
  5. FordCountry180
    Parkesburg, PA
  6. Tannersg1
    Tannersg1 Member
    Classified
