Power Steering Control Valve
Discussion in 'Technical' started by demo913, Feb 14, 2010.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Well pscv is shot. I have been looking at these manual steering conversion kits. Has any had any luck with these? What all will I have to do for this to work. It says will not work if the ps pump drives the water pump. I have a 75 351w Does this mean my water punp is driven by the ps pump. Thanks...
    http://www.mustangsplus.com/xcart/product.php?productid=831&cat=2095&page=1
  2. maverick75
    Do you have a picture of your belt setup? IF your ps pump does drive your water pump, all you would have to do is change to a non PS belt setup.
  3. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I think I might just replace the control valve. I just put a new steering box in and everything was real tight and still is its just the leaking that kills me. So im hoping that my new control valve wont leak.
  4. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    The control valve can be rebuilt. You can have it done or do it yourself.
    http://www.stangerssite.com/CanIControlValve.html
    If you are intent on reverting to non-power steering, there are a couple choices. The previous post shows a link to one type manual steering adapter. Not all fords have a removalble end like that. An alternative is to to remove the control valve only and keep the center link and make it a solid function.
    http://www.cjponyparts.com/manual-steering-adapter-1965-1966/p/MSA1/
    It even retains the grease fitting on the bottom side.
    R
