power steering leaking
Discussion in 'Technical' started by vvr210, Aug 1, 2013.
  1. vvr210
    vvr210 Member
    Vista,CA
    my maverick broke down on me earlier and it had something to do with the power steering.I was parked on the street and as I steered the wheels to pull out on to the street I heard something rupture.at first it sounded like my tire popped and it was leaking air but as I got under the car I noticed it was something around the power steering control valve.I went ahead and topped off the reservoir and I steered left and nothing leaked but when I steer right it starts spraying all the power steering fluid.I'm currently facing downhill and its hard to get under the car so I probably will get towed.does anyone have an idea of What might be the problem?
  2. Craig Selvey
    Sound like you blew out a hose or a seal. You will have to get it into the shop or school and take a look.
  3. vvr210
    vvr210 Member
    Vista,CA
    I blew a hose.I went to oreillys and they should be here tomorrow.should i replace the other hose?and once I replace the hose is there any type of bleeding required f
    or the power steering system?
  4. Dave B
    There will be bleeding involved. Replace the hose, and fill the system, then cycle the steering back and forth with the engine running, then add fluid as necessary.
    What hose was it? Considering they may all be 40 years old..you may want to think about replacing them...
  5. vvr210
    vvr210 Member
    Vista,CA
  6. Red1972Grabber
    Northern California
    I ordered two of those same hoses yesterday. They were $6.76 a piece through RockAuto. You may as well replace both of them since you are right there anyway.
  7. vvr210
    vvr210 Member
    Vista,CA
    They're 15 bucks each at oreillys but they will have them here by 10 in the morning.I would of bought them from rockauto but I want to drive my car by tomorrow.I just got a T5 installed in the mav so I want to break it in :chirp:
  8. Craig Selvey
    Hose looks like it was worn thru....doesn't look like it "burst". Must have been rubbing on something.
  9. 71gold
    yes...if this is your first leak, it won't be your last...:yup:
  10. Jamie Miles
    Alto, GA
    I've had a few
    I agree with Craig, that hose has been rubbing on something which is what caused it to fail.
  11. Krazy Comet
    (y):clap::bowdown:
    No doubt, but it goes with the territory...
  12. vvr210
    vvr210 Member
    Vista,CA
    My power steering has always leaked. .the only other thing sitting infront of the hose was the power steering
    cylinder boot.I think that's what's its called.
  13. vvr210
    vvr210 Member
    Vista,CA
    When i thread the new hose on do I need to put a little bit of teflon tape on the threads? When I took off the old hoses they had some type of sealant or tape on the threads
  14. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    Those hoses do a lot of flexing while enduring heat and pressure. Replacing both at the same time is a good idea. You might consider replacing the rest of the hoses as they all flex while driving and are probably just as old and brittle.
    Shouldn't need any Teflon or sealant of any kind. It's the flares and seats that do the sealing as long as the seats are good. Replacement seats for the control valve and power ram are available.
    Ron
  15. vvr210
    vvr210 Member
    Vista,CA
    Ok.and for the fluid I just need power steering fluid right? On the dipstick for the power steering pump it says to use automatic transmission fluid
