Power Steering, need some guidance
Discussion in 'Technical' started by 71mavk, May 26, 2014.
  1. 71mavk
    71mavk Member
    Hello, after spending a few hours I finally gave up. I've replaced almost every part of the power steering system in my 71 Maverick with the exception of the power steering pump. Still no luck, the p/s won't work either to the left or to the right.
    Before working on this, i had disconnected the hoses for months, and drove the car around like that. The car sits in the garage most of the time but i'm sure there is a lot of air in the system. Yesterday I replaced the control valve (from autozone) I did not adjust the nut (end cap). I assumed it is already adjusted. What am I missing?
    1. I tried bleeding the system, no luck. I did about 5 turns left/right with the wheels up (motor running).
    2. I took the car for a drive and there is no response at all from the p/s. It started leaking from somewhere around the control valve area.
    I'm not going to convert to manual steering for now, since i have already invested on all pats.
    I appreciate your expertise.
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    How about the cylinder?... did you rebuild or buy a rebuilt power steering slave cylinder?
  3. Bryant
    did you leave the belt on the pump while you had the hoses disconnected?
  4. 71mavk
    71mavk Member
    Yes, the cylinder is also new. And yes i left the belt on when i disconnected the hoses? do you think the pump is bad?
  5. Bryant
    the pump needs the fluid to lubricate it self. if you ran it dry all that time then you damaged it.
  6. doncomfort
    chillicothe oh
    I was thinking the same thing. I had a leak a long time ago amd let it run dry. By the time I got around to fixing the leak the pump was toast.
  7. 71mavk
    71mavk Member
    Yeah, that makes sense. i just figured since i don't drive the car much...it'll be ok. That is the only part i have not replaced. I actually have the rebuild kit for it, but getting the pulley out of the pump was a real PIA, so i gave up.
  8. doncomfort
    chillicothe oh
    They make a special puller for the pulley. They are fairly inexpensive. If you dont want to buy one, Auto Zone and Advance has them i the loaner tool program.
  9. 71mavk
    71mavk Member
    Awesome, thanks for your help.
  10. Craig Selvey
    I take my pump inside the store....and "borrow" it right on the spot!!
    Rodes Restorations in Gallion, Ohio is your friend. They specialize in power steering systems.
