power steering pulls hard right
Discussion in 'New Members Forum' started by FASTEDDIE1960, Feb 9, 2014.
  1. FASTEDDIE1960
    FASTEDDIE1960 New Member
    iowa
    1977 maverick
    trying to get a littlr info. just bought this 1977 maverick 302 auto power steering. it pulls really hard to the right. even if sitting still and reving up the engine will cause steering wheel to turn to the right, PLEASE HELP
    thanks
  2. blugene
    :Welcome:
    Wish I knew for sure. It sounds like maybe a valve in the steering assist unit is stuck or something.. Someone who knows about this may chime in soon .
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  4. mav1970
  5. Dave B
    Did you do anything to it? Usually when people replace the small hoses, and cross them, it'll do that.
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  7. Krazy Comet
    All the suggestions are good, but assuming someone hasn't been diddling with it, a stuck valve inside the control unit is most likely...
    Should bee easy enough to examine the end cap and hoses to see if someone has been working on those...
  8. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  9. FASTEDDIE1960
    iowa
    1977 maverick
    thanks
    thanks to all for the info. I just bought this little jewel yesterday and had to drive it about 200 miles with the crazy pulling and no heat in 5 degree weather!
    I really don't know if the guy I bought her from had done anything to her.
    is there anyone who knows which lines go where to the power assist?
    thanks for the great welcome
    not a lot of Mavericks out here in IOWA
  10. Krazy Comet
    The upper port on the valve goes to upper cylinder port, and lower to lower...
    BTW welcome...
    EDIT
    Kinda hard to see in this pict but upper on valve is at 45* angle...
  11. 71gold
    :Welcome:...:Handshake
  12. FASTEDDIE1960
    iowa
    1977 maverick
    steering pull
    thanks for the photo. hopefully it will get above 10 degrees sometime this week so I can get under her and check this out.
    thanks again
  13. simple man
    simple man Member
    Bunnell,Florida
    There is a grease fitting on the valve. It wouldn't hurt to give it a shot! Hand grease gun only!!! I hope it warms up for you! I struggle when it goes below 50°! :)
  14. lm14
    lm14 Member
    Iowa
    Welcome from SE Iowa, and there are more Mavericks in Iowa than you probably think!
    SPark
  15. FASTEDDIE1960
    iowa
    1977 maverick
    p.s. hose routing
    thanks,
    i got the valve off today and it is junk ordered a reman, whoever had this before did a little cobbling with the power steering hoses had them rigged with connectors.
    Does anyone know where the pressure and return lines from the pump connect to the control valve? just want to be sure he did not cross the lines when he added all these connectors
    thanks folks
