power steering pump need help
Discussion in 'Technical' started by craigs mav, Jun 23, 2006.
  1. craigs mav
    craigs mav Member
    arizona , avondale
    1975 chevy el camino
    well my power steering pump is leaking and my step dad told me to put powering steering conditioner in it along with power steering fluid do you think this will fix my problem it is leaking where the wheel with the belt connects with the rest also if i have to buy this how much will it run me also is there anyone here that has one i could buy if i have to
    thanks -craig
  2. Jamie Miles
    What your step dad suggests is only a quick fix. I'd just go ahead and replace the pump and not have to worry about it again for years to come.
  3. don graham
    $48.89 at napa. pobably less at pep boys or checker.:)
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    :slap: dang. i just paid 75.00 at autozone.:cry: well my daughters did(fathers day present)
  5. 71gold
    let it leak...if you stop it there it will just start leaking somewhere else...take it off...take it all off...frank...:bouncy:
  6. don graham
    i keep napa online in my favorites so i can check prices of stuff on ebay. :)
  7. scooper77515
    If I am not mistaken, that leak is only a brass seal that can be pressed in. I don't think you need to replace the entire unit. It will require a good bit of disassembly to get to it, and be very careful, there are about 200 (mild exageration) little springs and spring-loaded blades in there that will end up all over the garage floor. You will never find them all if you let them come apart.
    Overall, though, not too difficult of a job, but really messy with fluid ending up on everything.
    On second thought...you could save the hassle and time and swap out the entire unit :huh:
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    50 dollars and 20 minutes sounds like the easiest and best way to me. Other than removing power steering completely (which is my future goal).:2cents:
  9. don graham
    i think the rebuild kit was over $20. i'd save the time and hassle and buy the whole unit. be done in 1/2 hr.
  10. maverick75
    buy a new one
    i rebuilt mine and it took like 3 days and 3 manuals...wish i could have that time back...
