power steering pump
Discussion in 'General Maverick/Comet' started by wolfheads, Jan 5, 2013.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I just installed a rebuilt power steering pump on my 73 mav about a month ago and also replaced the control valve since it was out of commission as well. The pump is whining more than usual and the fluid level is where it's supposed to be. There are no leaks and the power steering is working fine. Just concerned about the noise. Are these model fords bad about the noise or do I need to return/replace the pump?
    Thanks
  2. scooper77515
    Shouldn't be whining at all. I would take it back.
    How does the fluid look and what kind of fluid are you using?
  3. Joe Dirt
    did you flush and bleed the system? assuming you used a high quality type f trans fluid as required?
  4. injectedmav
    injectedmav Member
    Georgia
    It's a long shot since it has been running for a while, but it may have air in the system. I made a vacuum adapter out of a conical rubber plug from the hardware store by drilling a hole in the center all the way through and attaching a rubber hose long enough to attach to the vacuum port under the carb. Put the plug end into the fill tube on the pump and use pliers to pinch it off and release it to use engine vacuum to pull the air out of the system. Just have to be careful not to pull fluid into the engine. A container that is rated for vacuum (like the ones used for vacuum bleeding brakes) can be used to prevent fluid from reaching the engine if it becomes a problem.
  5. rthomas771
    Did you turn the steering wheel lock-to-lock several times to burp the air from the system?
  6. wolfheads
    wolfheads MadMav
    Florida
    The fluid I used was power steering fluid. It was clear. I've always used regular transmission fluid in the past for the power steering and don't recall any problems. If I remember correctly, I checked the level and it was still good but I think the color had turned a milky darker color. I did turn the wheel lock-to-lock to remove the air from the system. Should I drain the system and replace with type "F" trans fluid?
  7. simple man
    simple man Member
    Bunnell,Florida
    If the pump is a stock replacement, you should use type F fluid! That " power steering " fluid is not suitable for our cars! I even use type F fluid in my Ranger's power steering. It works better, the leaks have stopped, and the whine is almost non existent! :thumbs2:
  8. wolfheads
    wolfheads MadMav
    Florida
    replacing the fluid
    Is there a specific procedure in bleeding and flushing the system? I'm just hoping that the pump isn't damaged but if it is, I'll just replace it. They're not that expensive.
  9. Joe Dirt
    damage is done replace pump and use proper fluids and flush the system
  10. wolfheads
    wolfheads MadMav
    Florida
    I'm going to replace the pump. It seems to work fine till the fluid warms up and then the whining starts up real bad.
