The other day I found out for sure my P.S was leaking and i was trying to find a tech article about changing it to manual but couldn't find anything. any help would be great i will be doing this my self, as i was always told hands on is the best way to learn.
you need a....manual drag link and pitman arm...:Handshake to do away with the pump...you need a different pulley and belt...
I have a manual set up off of my other car.are most parts replaceable? I want a new front end. is it hard to do the swap? does everything bolt into place or is there mods I have to do?
everything bolts into place...does the donor car have the same motor? you say "you want a new front end" what does this mean...
the donor doesn't its a 6 and mines a 8 and new parts every where I can, tie rod ends, control arms thats what I mean
