Power Steering
Discussion in 'Technical' started by eburciaga, Sep 29, 2010.
  1. eburciaga
    eburciaga Member
    Orange County
    1974 Maverick 4 Door
    what would be the things i need to put power steering on my car, its a 74 302 v8
  2. maverick75
    Center rack, tie rods, Idler arm, pitman arm. Steering ram with the bracket. PS gear box, pump and pulley set up. Thats pretty much it.
  3. darren
    Its quite a bit of work. You may want to re-think it. Its not a very good system(prone to wear and failure) and road feel is terrible.
  4. flynbrd
    flynbrd Member
    when the power steering is fresh and dialed in the system works fine. Considering most systems are worn out people rather switch to something else rather than spending the money needed to repair it.
  5. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Lot of work but worth the effort for "non-performance" vehicles in my opinion.
  6. maverick75
    Are you guys kidding with the hard work part? If you have all the parts its really simple. I did the swap when i was 17 and i had no experience with anything about steering. I managed to do it in under an hour. All i needed was a diagram of the system and a repair manual to get the settings down. I was also fortunate to have a shop next to me that made me a set of lines using the old ones as templates. But after i drove it I was really disapointed with the road feel, I wish i hadnt sold the manual parts.
  7. indyman13
    indyman13 Member
    You're right, I should have said looks hard.
  8. flynbrd
    flynbrd Member
    on my power steering I'm toying with the idea of using the thunderbird sc power steering controller. In theory when I apply 550mvs to the solenoid the valve restricts flow by about 50%.
  9. Bryant
    do you have more info on this tbird sc ps controller? ive never heard of it.
  10. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Mine has a later model pump, and it doesn't have that overboosted, numb feel that a lot of old Fords do. The wider tires probably help too.
  11. maverick75
    ^^^Thats good news. Im going to swap to that type of pump when i do a serpentine conversion. And also run 225 up front.
  12. flynbrd
    flynbrd Member
    I'm curious to see if the 302 6901 headers will hit the newer style power steering pump.
    Heres the link for the variable assist
    http://www.aa1car.com/library/2004/bf10434.htm
    I would like to run the whole system but that is serious work on the column.
  13. facelessnumber
    Memphis, TN
    '71 Grabber
    I have no reason to think they would, but I will be finding out soon.
  14. Moglie
    Moglie Member
    North Carolina
