Prepping engine for paint...
Discussion in 'Cosmetic' started by scooper77515, Nov 19, 2007.
  1. scooper77515
    Next time we get a front and the humidity drops below 90%, I will paint my engine.
    My question is...how to I get it clean and get all the oil out of the casting bumps? There is no paint on it, just clean oil from lubing the bearings and cylinders.
    Can I use GunScrubber or something like that to shoot the oil off and leave good adhesive surface?
    Or is it going to require elbow grease and lots of rags?
    Heads are not on yet. and I will probably paint those off the engine before I mount them down.
  2. newtoford
    newtoford Member
    New Castle Delaware
    i used gasoiline and a paint brush to put it on and then scrubed it off with water and let it dry, but theres probably a better way
  3. blugene
    Same here, but then sprayed it down with brake parts cleaner.
  4. scooper77515
    GunScrubber is pretty much the same thing. Almost like Acetone in a spry can. It dries really quickly and leaves no residue.
  5. Jamie Miles
    I have had good luck using the aircraft paint stripper that comes in the spray can as a degreaser. Works better then that "stuff" they call degreaser, actually.
  6. scooper77515
    Hmmm. :scratchchin:I will look into that. Then, how do you get the paint stripper off? Isn't it a thick gel (only ones I have used were thick and gelatinous).
  7. 71gold
    Moderator....Scooper said..."gelatinous"...what's that???:huh:
    sounds nasty...:yup:
    ...Fcooper...:D
  8. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    :Nothing_f
  9. newtoford
    newtoford Member
    New Castle Delaware
    the last paint stripper i used came out like a white foam but it worked great
  10. scooper77515
    Nothing worse than a Gelatinous Stripper:yikes:
    (think about it a second...)
  11. NAFORD302
    NAFORD302 Member
    SILEX MO
    Says Who
  12. scooper77515
    :biglaugh::whistle:
    I couldn't help myself. All the select words lined up in a way I just HAD to say it.
    But if you really think about it, the best strippers have gelatinous parts, in all the correct places...:thumbs2:
  13. NAFORD302
    NAFORD302 Member
    SILEX MO
    I KNOW :clap::yahoo::bananaman
  14. scooper77515
    Whew! we got a little off topic there, didn't we:biglaugh:
  15. Jamie Miles
    May want to see a doctor about that.
