Prime the oil pump ?
Discussion in 'Technical' started by elliot, Jun 6, 2006.
  1. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    Hey guys , I`m regasketting my 5.0 and was wondering if I need to take the plate off the oil pump and pack it full of lube before I put the engine back together or can I just prime it with a drill before I start the engine ?
    How much HP do y`all think my motor will make ? Its a 5.0 with cleaned up heads 500 cfm eldelbrock carb , dual plane intake and a set of black jack headers. I was thinking 215 - 240 HP ?
    Thanks
  2. igo1090
    igo1090 Member
    catonsville, md
    just do the drill bit. hp sounds about right if you are talking rwhp.
  3. don graham
    i just prime mine with the drill. don't forget it's reverse.:)
  4. elliot
    elliot Member
    Boubon MO
    Thanks for the help guys I`ll be getting it all put together tonight :29: .
  5. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
    I did mine with a drill. Just to be sure i held it there for a couple on minutes just to make sure the oil was under enough pressure. i didnt have a gauge.
  6. bmcdaniel
    You want to spin the drill counterclockwise until you see oil at each rocker arm. Then manually turn the crank 1/2 turn and spin the drill again.
