Printed circuit in instrument cluster
Discussion in 'General Maverick/Comet' started by will8069, Oct 19, 2009.
  1. will8069
    will8069 Member
    Garland, TX
    1974 Comet 250 straight 6
    So, I removed the instrument cluster for a few reasons:
    1. Paint it white
    2. Install LED's
    3. Replace bulbs for general illumination (I can't believe that I thought all three were out.)
    Well, turns out the circuit was pretty torn up, so I'm looking for a new one. Where could I get one of these? Does a company make them or should I put an ad up in the wanted section? I need it pretty soon.
  2. Popbumper
    Popbumper PINTO unashamed
    Dallas, Texas
    Hey Will:
    Do you know if these printed circuits deteriorate often? Is it a common problem? Anyone? I have been thinking about reproducing these, as I work in the electronics industry here in Texas (Richardson, as a matter of fact). These would not be that big of a deal to remanufacture, I have the resources.
    Chris
  3. Craig Selvey
    Nobody makes new.
    I have lots of used circuits. I can sell you without any of the hard plastic if that is what you need. Email me directly (see below) if I can help.
    Chris: I see no need to reproduce these....as there are lots of used ones out there, IMIP (In My Informed Position)
  4. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Circuit Board
    North gets the rust and Texans get baked plastic. A fact from Jack
    Texasjack
  5. Popbumper
    Dallas, Texas
    Thanks Craig, I appreciate the feedback on the circuit board.
    Jack, true that. My instrument cluster was POWDER.
    Does anyone have a need for REPRO CLUSTERS? I have a way to do them.....
    Chris
  6. brainsboy
    brainsboy Member
    Tampa
    I have lots of printed circuits. I have not really seen these go bad.
    The problem I have is I cant find the clear plastic window for the gauges. All the ones I have are milky or have a frosted look to them. I tried sanding and buffing one out but the milky part seems to be embeded into the plastic completely.
  7. darren
    You need a northern one. (y)
  8. Earl Branham
    Lugoff, SC
    If you get the lens set from a '69-'70 Mach 1, the lens is the same and works fine, and, it is new. You will have the two smaller lenses that you can't use, but you will have a new cluster lens.
  9. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Panel
    While you have the panel apart, if you remove the blue caps off the bulbs, you will increase the dash lights output 100%.
    Texasjack
  10. will8069
    will8069 Member
    Garland, TX
    I know that this post is a little old, but I just kept putting it off. Do you have any with the hard plastic? If possible, I would rather not meddle with putting that on the plastic.
  11. Craig Selvey
