Pro Charger question
Discussion in 'Technical' started by MikeG747, Jun 7, 2009.
  1. MikeG747
    MikeG747 Member
    Arkansas
    If anyone has installed a Pro Charger I could use some input. The bolts sent to mount the unit to the head are 7/16". I am running RHS Heads which have one 1/2" hole & two 5/16" holes. :huh: See pics below. The 7/16" bolts would work on the old stock 302 Heads but not on the RHS. I told Pro Charger I would be running RHS Heads. Will I have to drill & tap the 2 smaller holes & Heli Coil the large one? Give me your input please.
    Thanks,
  2. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    You can get the inserts for the larger hole in the head off of late model heads or from ford.The lower bolts you could tap or just use smaller bolts to fit the head size.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The insert is Ford Part Number F4ZZ-6E086-A
  4. MikeG747
    MikeG747 Member
    Arkansas
    Thanks for the input & the part # guys. I will try to get these today. (y)
  5. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    step down studs will do.
    They are available for a number of combinations and thread counts
  6. MikeG747
    MikeG747 Member
    Arkansas
    Thanks for the part #. Looks like this will work perfect. (y)
  7. maverick1970
    Missouri
    Glad it was helpful. Went through this myself and I have kept the part number handy in case I needed it again.
