Problem problem>>>..... D:
Discussion in 'Technical' started by RobbRudzek, Dec 1, 2010.
  1. RobbRudzek
    RobbRudzek Handsome Robb
    Oregon City, Oregon. Prob #13 on the top 20 most b
    1975 Maverick, inline 6... (NEW UPDATE) ... IT LIVES!!!! WHOOOT!
    SOoo....
    N00B guy here again... with issues...
    Car: 1975 I6 Maverick...
    Problem: unknown.
    Symptoms: Engine WONT FIRE UP!
    So heres what happens... i get in car, annoying buzzing noise goes off indicating door is open. get inside, put in key, can hear car trying to fire up...
    no avail... several times... no avail....
    so i know this isn't really that good for the car, but i noticed my additional fuel filter was dry, so i put some fuel in the carb, turned key, WHOOM fired up... but stopped... fuel line, still dry...
    what does this mean? D: please help. :cry:
  2. don graham
    Sounds to me like the fuel filter, or the fuel line is clogged, or the fuel pump needs replacement. :)
  3. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    What Don said.
    Go to the inside fenderwell(driver front)and follow the metal gas line,along the frame.Disconnect the rubber line,and set it off to the side.hook up another pc.of rubber gas line,and drop it into a gallon of gas.Prime the carb,and fire it up.Might take a few attempts,but if the pump is pumping it should run on it's own.Then just replace the rubber line coming from the tank to the metal line.If it doesn't run on it's own after a few minutes,replace the pump.
    Hope this helps.:tiphat:
  4. indyman13
    indyman13 Member
    Little Rock, Arkansas
    What is this "additional" fuel filter? I'd think that the more filters you've got on the supply side, the more chances and restrictions you'll have to deal with. My 73 with a straight six 200 has one clear plastic filter on the fuel line located at the carb. When the screen starts losing it's shiny finish I change it out. I'd start somewhere around that thought since it's the least expensive gamble.
    As Don said, next move downstream would be fuel pump. Disconnect the fuel line before the filter and crank the engine to see if fuel is being delivered. Make sure and capture the fuel somehow so you don't have gasoline all over the place. Fuel pumps are a pretty easy fix expecially on inlines.
  5. Bob Wiken
    Fayetteville, Arkansas
    Not to overlook the obvious, do you have fuel in the tank?
    someone stole the gas out of my car a couple of years ago. It caused all kinds of havoc til I figured that out.
  6. rthomas771
    Having an additional fuel filter is redundant and puts extra strain on the fuel pump.
  7. Bryant
    my first guess is out of gas.
    if you have gas then you need to trace the fuel lines and see where the gas stops flowing at.
  8. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    1976 ford maverick 302v8
    Aye checking the tank is a sure fire bet... i had put 20 bucks in the mav, parked her, next day woudln't fire, no fuel, replaced pump... and still nothing... then it then i realized.... NO FUEL..... now to just get that gauge working... lol! It wouldn't be a bad idea to go ahead and take a look under the car as well, check the fuel lines and make sure they are still solid... buddy's 73' torino had a fuel line rot out, small pinholes can cause the mech pumps to not suck the gas from the tank too :(
