problem with my oilpan
Discussion in 'Technical' started by rolandag2, Apr 14, 2007.
  1. rolandag2
    rolandag2 Member
    Dickinson, TX
    1970 Maverick Grabber
    I tried to use the oilpan for my motor in my car and it wont fit. The girdle is messing that all up, removing the girdle is not an option. So, I will have to modify the stock 5.0l pan that came with the engine when i got it. I know that the stock pan will clear the girdle but i will have to make it clear the steering gear can anyone help me with measurements or if done b4
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    do you have a front sump
    if stock 5.0L pan its probely dual sump
    you just need a front sump
    P.S. TALK TO ANDYSUTT HE HAS A DEEP SUMP 302 PAN if you need a front sump
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Yes, yes, yes,, front sump oil pan is all you need, pump pickup too.
    Dan
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I've fought that battle and lost it (also).
    I tried everything to get a rear-sump pan that would hold an adequate amount of oil behind the steering linkages - no such luck.
    Like the rest of the guys, I had to go with a deep FRONT sump.
    There's one up for sale in the classifieds now. http://mmb.maverick.to/showthread.php?t=31958&highlight=oil+pan
    There's also ebay:http://cgi.ebay.com/ebaymotors/FORD...013QQitemZ230116846641QQrdZ1QQsspagenameZWDVW
    comes with the oil pickup.
    Although they're a major PITA when r/r'ing the engine, it's the next best thing to a rear sump.
  5. rolandag2
    rolandag2 Member
    Dickinson, TX
    I have a front sump pan that is the stock from the motor i'm pulling out will that work
  6. baddad457
    I'm going thru the same problem with a main girdled 331. I bought a pan off ebay and it should be in next week. I'll let you know if it fits. Mine was contacting on the two rear main studs. The pan I bought has a "kicked out" section at this point where the stock pan doesn't. If you want to spend the bucks, Canton makes a pan that for sure fits with a girdle but it's a $300 pan. The one i bought was $90 with the shipping.
  7. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Thanks for the plugs guys. I just found this thread. I still have the pan if anyone is interested...
