Prototype Tranny for Taurus?
Discussion in 'Technical' started by Maverick-Austin, Mar 25, 2004.
  1. Maverick-Austin
    Maverick-Austin Maverick Driver
    West Virginia
    1971 Ford Maverick
    ok, i know its not a mav, but its a ford, and you guys are experts at this so i'd come to you anyday before i'd go to a mechanic around here. Ok, Details:
    1991 Ford Taurus GL 4 door sedan
    3.6 litre V6
    Front wheel drive
    Mom's car
    Problem:
    Car hesitates SEVERELY, will not move until pedal is fully to the ground, then slowly goes, and will not shift out of first. We put 6 quarts of tranny fluid in it and it still won't go. There are no leaks surprisingly and we are pretty sure the gears aren't stripped. I think mom likes to nuetral bomb :p
    Any advice//suggestions would be great! thankS!!
  2. mavman
    mavman Member
    Arkansas
    if it was mine, I'd pull the pan & have a look-see. I bet you'll find all sorts of junk in there. Go ahead & change the filter too. Not that hard to do, and if you get real lucky, the filter may be clogged, causing exactly what you describe. Will it drive in reverse OK?
  3. Maverick-Austin
    West Virginia
    1971 Ford Maverick
    drives in reverse fine....but we just replaced the filter......
  4. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Your trans is electricly operated. Have someone check it out with a scan tool. Sounds like fluid is being allowed to move. A solinoid may be bad
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    You'll never stop putting transmissions in that thing.
    If you can manage to get it driveable again without dumping a pile of cash in it, your next custom installation should be a for sale sign in each window.
    Just my opinion, but it's pretty common for a Taurus of that vintage to be on its third or fourth transmission.
  6. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    do you mean the engine hesitates severly? if so its the timing belt
  7. Maverick-Austin
    West Virginia
    1971 Ford Maverick
    all belts are good, its definetly the trans. I heard a lot of things about the solinoid. I'll try to go get that checked. And if this helps, when you rev up to move, there is a sloshing sound in the engine bay, maybe fluid?
  8. 71gold
    had a van they wanted $2500 to fix. i put a bottle of " trans medic" in and let someone else hold it. i saw it about 8 mo. later and the lady said she loved the van. i came home and put a bottle in the mav...frank...:bananaman :bananaman
  9. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    I had a couple of those cars....the tranny went out in both of them. One car went thru two trannies this is normal for these. There is a fix out there from ford...some kit that will fix the problem but not sure what it is. I would just dump the car...quickly.
  10. Cleaver
    Cleaver Member
    MD
    Chel
    HAHAHAHA.:p . That hit me funny for some reason (It could be the 2nd margarita), but I just had a recollection of me and my buddy at the age of 16 drifting his moms 74 Olds Omega backwards downhill on a little country road and doing (I always heard it called a neutral drop) into Low1. It would leave a funny looking cursive "s" shaped donut on the road as the car was still moving backwards with the right rear tire blowing plumes of smoke before it caught and finally started moving forwards back up the hill. Surprisingly that car put up with his abuse for several years.
    I wonder if an electronic controlled car and trans would let you do that now? HUMMM?:rolleyes: Anyone planning on a rental soon.:D
    Cleaver
  11. Maverick-Austin
    West Virginia
    1971 Ford Maverick
    can someone tell me where i can locate the Solinoid on the tranny?
