I'm just wondering if anyone can get detailed pics on the ps and alt brackets I have a set that need to be put on an 83/84 carbed 302 got the front sump pan/timming cover for a mav to fit it in the car
good deal, the lil 250 with a/c is going out for 302/no a/c I think all the brackets for the ps/atl is like a 5 pcs set? i have like 7 cause i have an incomplete set and my mechanic needs to know how to mount them also converting the serp engine back to the mav pully system to make sure the brackets will work
I believe the PS and Alt brackets are the same with or without A/C but it might be better for someone without A/C to take the photos so you can see them better.
If you go to my gallery you can see the non AC bracket. Im pretty sure its different than the AC version. For the Alt its only a top and bottom bracket and the spacer.
I believe the brackets are the same there is just a spacer for use without AC to take up the space of the missing bracket.
