quarter panels
Discussion in 'General Maverick/Comet' started by lilfarley, Oct 14, 2008.
  1. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    does anyone know the dimensions of the quarter panel repair panels from autokrafters
  2. YotaRacer
    YotaRacer Member
    Gloucester VA.
    75 Grabber
    65-3/4" top (front to back)
    62-1/4" bottom (front to back)
    25" front (at b-pillar top to bottom)
    23" back from bottom to top of quarter.
    They definitly need some massaging to replace the existing quarter. they are designed for both 2 and 4 door cars. If you are going to use on a small bumper car you have to add some metal to fit right. If you need more ics let me know and I will get themfor you.
  3. lilfarley
    Central City, Iowa
    are those the full panels or the cheaper patch panels i was wondering about the patch panels
  4. Dave B
    They don't make the patch panels, it was a pipe dream.
  5. YotaRacer
    YotaRacer Member
    Gloucester VA.
    75 Grabber
    full quarters and they run $292.95 before shipping. word of advice do NOT cut out your quarter panel until you have the new one there. It is lacking the material for welding it back to the original spotweld points.
  6. lilfarley
    Central City, Iowa
    looks like i make my own patch panels than
  7. Craig Selvey
    Not completely a pipe dream. I am still working with them on it. When I have firm plans from Auto Krafters...I will let you all know.
  8. Dave B
    Well then, I better put away my Meth pipe!!! :Handshake
  9. white trash
    white trash Member
    Leland, NC
    1969 1/2 Maverick 6cyl auto field find junker
    I hope you do make these patch panels to sell. It seems most of these cars are rusted out at the bottom and there is not much sense in replacing the whole panel for that. I plan on making my own but they will not be shaped quite like the original. I starting making one up and it is close enough. I will post pics when I am done
  10. lilfarley
    Central City, Iowa
    Craig do you know how big they will be it would be nice if they were about at the body line down
  11. Craig Selvey
    Not EXACTLY sure......but that should be close.
  12. lilfarley
    Central City, Iowa
    sweet that would be perfect for the drivers side of my car
  13. Rando76
    Rando76 Member
    Claremore, OK
    I agree. I'd be more interested in the patch panels than a full quarter for my projects. :thumbs2:
  14. 72MAVGRABHER
    Roanoke, Va.
    i'd agree, i used pretty much a full quarter panel skin for my drivers side, had to flange the original sheet metal to spot weld to,and ended up cutting the passenger skin down to just a patch for the lower.... lot of wasted metal. And, the lines arent that good on the skins,(I.E. rolled edges instead of sharp at the door, rear corner light holes are pushed back farther than original) but it's all we have now....
  15. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    What is the deal with Autocrafters advertising parts in their catalog that they cannot provide? First it was the floor pans. Now it is the quarter panel repair panels. I'm starting to wonder how much of the stuff in their catalog is saleable! :mad:
