quarter pannels
Discussion in 'General Maverick/Comet' started by cyclonewill, Nov 30, 2006.
  1. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    comes up error for me
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
  4. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
  5. Dave B
    At one time Sherman used to buy them from Cross Canada, both companies have something to do with each other.
  6. bmcdaniel
    Yeah, Autocrappers gets theirs from Sherman, they used to even have the same part numbers in their catalogs. And the fit was horrible. Had 'em on my car for a short time, ended up getting NOS pieces and using the repops to make patch panels.
  7. mightymav72
    mightymav72 Member
    Sevierville,Tn
    1972 Ford Maverick with a 351 Windsor
    I used a SHERMAN years ago,not a great fit.I had to really work the panel,and use alot of filler.If your have ever used,for example a GOODMARK,panel you,ll be disappointed.Then again what choices do we have.
  8. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    What I found is that anything beyond the outer skin is useless. Initially I was going to try to use all of it, but it seems to be stamped too large to do that -- you can't line up all the edges at once. If you cut off the top ledge, front and rear, and lower ledge, what's left seems pretty good to me. It certainly looks a lot better than the quarter that WAS on my Grabber. :)
