Hi, somebody know which weatherstrip i can use to replace my old quarter windows´s weatherstrips???? 1974 Ford Maverick, two doors, 6L 250ci
No one makes them new, so you're stuck finding used ones. Post an ad in the Parts Wanted section and maybe someone can help you out.
I had the same problem with mine. I went shopping at the wrecking yard and ended up with 82-ish honda accord. The honda is bigger so I cut it to fit making the seam at the bottom forward cutting it at a 45 degree angle and using black silicone at the seam. I have since noticed the the intermediate chevy cars use a seal on thier trunk that would work too (probly better and easier to find). Using the same trick where the ends meet.
