How do i go about remouing the quater window chrome trim/boomerangs. they are all ate up from time and the elements and need to go
There is one Phillips screw from the outside as you can see. From the bottom side is a nut that can easily be reached if the interior qtr trim panel is removed. However, if you have long arms and are a bit of a contortionist this nut can be reached going through the trunk. I have done it and recently but it's not fun.
