Question about accelaration
Discussion in 'General Maverick/Comet' started by chevyandford71, Dec 8, 2011.
  1. chevyandford71
    chevyandford71 Member
    Apex, NC
    1971 Ford Maverick Grabber, 1991 Honda CRX HF w/B18A1 swap, 2001 Honda CR80R
    so as many of you know my maverick is my daily driver given im a junior in high school. while driving ive noticed that when i go up an incline (no matter how big) the car seems to momentarely lose accelaration, it hard to describe unless youve driven the car, but if feels odd and like something is wrong. Note: it just started this behavior a week ago. Any ideas on what might be the issue?
  2. Bryant
    what engine and carb do you have?
    are you giving the gas pedal any extra pressure when you start up the hill?
  3. maverick75
    Gravity :D
    Have you tried kicking it down a gear manually?
    Actually the kick down rod should do it automatically, but I know a lot of people remove it. So check to see if it's still there.
  4. captainmack
    captainmack Quad Door
    As though under load there is a flat spot?? Sounds like a ignition problem maybe.. Make sure the dist. cap and rotor have no corrosion, and spen 100 buck and get a Pertronix II to replace points. Could be carburator too.. need engine info..
  5. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Trash in fuel filter maybe? :huh::16suspect Original sock type fuel filter collapsing -maybe.
  6. Mavman72
    screen rotted off fuel pickup...
  7. CaptainComet
    Makes me wonder if the float in the carb is a little low to begin with. The incline could make it worse.
  8. Acornridgeman
    Wisconsin
    Check the acccelerator pump in your carb.
    (y)
  9. chevyandford71
    Apex, NC
    Sorry for having not responded sooner, engine is a bone stock 250 1V w/c4 tranny
  10. 71gold
    on flat ground, does it do it when you give it gas?
  11. Bob Wiken
    Fayetteville, Arkansas
    I'd guess accelerator pump too
  12. chevyandford71
    Apex, NC
    Not often, though it does occasionally
