Question about cutting coil springs
Discussion in 'Technical' started by Tim V, Apr 30, 2007.
  1. Tim V
    Tim V Member
    Harriburg, Oregon
    I bought a set of 1 in. drop front coil springs for my 71 maverick (V-8). Its not setting as low as I would like. I want to go 1 1/2 to 2 inches lower.
    Would like to know how much to cut off. I was thinking 1 coil:huh:
  2. Mavaholic
    With the car on the ground with full weight, you can measure the distance between the coils. That will give you a rough idea how much 1 coil will drop the car. Still, speaking from experience dont cut more than 1/2 of a coil at a time.
  3. yellow75
    Tillamook Oregon
    Tim, welcome to the one of the greatest Mav/Comet sites on the internet. Cant answer your question about cutting springs but if you cut a coil and it is too much I can help you out with more springs.
    Where are you in Oregon? I am over here on the coast in Tillamook but spend most my weekends at the dragstrip in Woodburn.
  4. Tim V
    Tim V Member
    Harriburg, Oregon
    I live in Harrisburg, I grew up in Florence.
    I go to Woodburn about twice a year, If I mess up these springs I may need more.....
  5. Tim V
    Tim V Member
    Harriburg, Oregon
    Thanks Mavahalic
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I cut 1 coil off of stock 250 six cylinder coils, and mine is just right for me. I agree with mavaholic, better to cut a little at a time than cut too much and be sorry.......
  7. scooper77515
    I ended up doing three separate cuts before I was happy with mine.
    This question cannot be answered definitively....there is no "correct" answer. Each brand and model of spring has it's own "personality". Mine were VERY tall, they were Heavy Duty springs from JC Whitney, made for 4X4 and had only 6 or 7 coils while being 4 or 6" taller than stock springs. I only had to cut 1-1/2 coils off to get an acceptable ride height, but on my stock springs, they had 12-15 coils and I would have had to cut up to 3 coils off to get the same height.
  8. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Also keep in mind that you can go only so low by cutting springs. Any lower, and you risk damage to the ball joints...
  9. Shinysideup
    Shinysideup Chillin the most
    town
    car
    good point, not to mention bump-steer issues. good luck to you.
  10. stmanser
    Davenport, Iowa
    when i cut my 1 coil off.. it dropped my car 1.5"
  11. Tim V
    Tim V Member
    Harriburg, Oregon
    Thanks for all the great info. I cut one round off and Dropped about 1.5''- still to high
    so I cut off 1/2 round more and the little lady got home and got stuck doing my HONEY DO list. Will get them in this weakend.
    I hope this isn't to much to mess up the ball joints?
    What do you guys think
  12. T.L.
    T.L. Banned
    Southern Colorado
    Well, let's see a pic...
  13. Maverick Man
    California
    i would have told you too cut off 1-1/2 coil right off the bat. ;)
    my 2 cents http://www.maverickman.com/Suspension.html
    end of post. (y)
  14. vern
    vern Member
    New Jersey
    Why do you guys cut the springs instead of buying shorter springs??? Is it that simple to do cut off wheel on a grinder or plasma torch??? Looking to lower the front on my mav. soon and trying to decide what to do.
  15. T.L.
    T.L. Banned
    Southern Colorado
    Because cutting coils is free. Buying shorter springs is not, and you'd be hard-pressed to find a set of shorter springs for a Maverick anyway.
    Use a cut-off wheel or a Sawz-All. I don't recommend torches or applying heat to springs....
