question about engine fitment
Discussion in 'Technical' started by carcrazy1964, Jun 20, 2015.
  1. carcrazy1964
    carcrazy1964 Member
    1976 ford maverick
    Just purchased a76 maverick with 250 i engine i have access to a351 and transmission out of a78 ford econoline my question is would this motor and trans fit into this maverick with out heavy modification i know a302 will fit and bolt up to the c4 will the 351 do the same ? I'm assuming the transmission in the van is the c6 would this fit In the maverick to or would it be to wide In the trans tunnel ?
  2. mav1970
    You can do a search on "C6" and see where this has been discussed before - it is a big trans for a little tunnel
  3. carcrazy1964
    carcrazy1964 Member
    1976 ford maverick
    Yeah i was afraid it might be to wide for the tunnel and I'm not looking too go modifying that area if the c4 bolts to it then i guess imll use that motor if not i,ll find a good running 289 or 302 not looking too build a race car just a nice cruising one
  4. Krazy Comet
    A 351 is also tight fit but is doable... If possible I'd swap the 351 & C6 for a 302 & C4...
  5. mojo
    If ur not looking for a power house, I wud go for the 289/302 based/C4 if modifying is not on the agenda.
  6. baddad457
    That transmission in the van could well be an FMX, not a C6. FMX will fit in a Mav. Little harder to get parts for but they were tougher transmissions than the C4's. The FMX bell unbolts from the outside. The bell and tailhousing will be aluminum, the main case is cast iron
  7. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    You can get c4s now that will handle over a 1000HP,get the full rollerized planetary trans,doesn`t take much HP to pull them & they hold up really well.
