Question about trim in the corners of rear window
Discussion in 'General Maverick/Comet' started by 66170MAV, Mar 9, 2012.
  1. 66170MAV
    66170MAV Member
    Lancaster Ca,
    Hey Guy. I want to put the windows back into this weekend but the two trim pieces that sit in the bottom corners of the rear window havent been recovered and returned yet. I was wondering if they can actually be replaced or installed with the window in?
  2. 66170MAV
    66170MAV Member
    Lancaster Ca,
    now lookin at it, it dont seem a problem
  3. yellow75
    Tillamook Oregon
    If they are the plastic type you are more than likely to break the studs when you try to put them in when the window is in place, metal ones no problem
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I agree. Put them in while the window is out. Others have had success installing them with the window in but I broke the studs.
  5. 66170MAV
    66170MAV Member
    Lancaster Ca,
    Thanks for the advice. Ill just wait till I have all the interior back in
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    If they do break, it's a pretty easy repair. Drill holes where the studs were, countersink the outside, epoxy in a pair of countersunk machine screws (with nuts on the inside), then refinish.
  7. yellow75
    Tillamook Oregon
    Now how am I going to sell him some when he breaks his :p
    Great tip :thumbs2:
  8. mav1970
    My 69.5 has the metal ones - I believe his later 70 model would also :yup:
  9. rthomas771
    I got mine metal trim from a 71
  10. 71gold
    I've never seen where the window in/out made a difference on installing these. the plastic is brittle is why they break the studs off. most I break are when removing...:yup:
    the metal ones are on my...junkyard pull list...
